GPWT wheels
they will fit but I believe the bolt pattern is so close that you need to file the holes out a bit
as far as bolt pattern.
I would be more concerned with the offset as the gpwt had the rear hubs offset quiet a bit .
you may have to put a steel spacer in the hub so the wheels dont rub.
f20 wheels will look good.
are you taking steel wheels off??
I am looking for a pair of rear steel.
if so email me
