JD 2010 ign coil specs
docmirror
I have no voltage coming from the coil, and the resistance is about 30Kohms. I'm pretty sure it's dead.
12V neg ground system on this. Wico DB Dist with new point and condenser.
Recommendations for a new coil? Is there anything special about that or the ballast to use? I don't want to use a 6V coil and burn it up.
Total resistance through the coil with or without external resistor should be about 3 ohms. A 6 volt coil will read
1.5 to 1.8 ohms. A '12 volt" coil will read about 3.2.
