Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
PN needed for JD 60 axle seal outer
Fred from Mo
03-20-2017 13:06:09
I have a leaky axle seal on the ol 60 and want to do the job right. Went to my trusty exploded diagram from Deer of the 60 with part numbers and was shocked that my local parts guy told me outer felt seal pn F 786R is obsolete. Is there a new number or a place other than deer to get one?
edinmo
03-22-2017 11:21:13
 Re: PN needed for JD 60 axle seal outer in reply to Fred from Mo, 03-20-2017 13:06:09
Fred, where in MO are you located. I'm near Joplin, we may need to compare notes sometime. I have a 60 leaking right side axle also.
Pete in MD
03-20-2017 20:16:18
Fred,
AA510R is the p/n for the inner oil seal. They're available from Deere for about $43 each.
You can do a lot better at NAPA or other parts places. The specs on the seal from the JD parts site are: 2.750" shaft diameter 3.756" seal O.D. 0.433" width Single lip, Nitrile, garter spring seal
Mark-Ia
03-20-2017 13:33:11
The outer felt seal is just a dust seal. You can wash the original felt out in gasoline and then oil it and reuse. The axle seal is inside the axle housing. The powertrol and axles need to be removed.
Fred from Mo
03-20-2017 13:40:36
 Re: PN needed for JD 60 axle seal outer in reply to Mark-Ia, 03-20-2017 13:33:11
You wouldn't happen to have the p. For that inner seal would you?
Fred from Mo
03-20-2017 13:41:09
 Re: PN needed for JD 60 axle seal outer in reply to Fred from Mo, 03-20-2017 13:40:36
Part number that is
Old Popper
03-20-2017 15:10:43
 Re: PN needed for JD 60 axle seal outer in reply to Fred from Mo, 03-20-2017 13:41:09
I'm no expert with the parts manuals but I came up with AA510 R. Hope this helps.
