JD 4440 1980 Quad Range Hard to Shift
Here's the scoop: Tractor difficult to shift between (synchro?) gears. Physical drag on shift lever. Ranges work fine. Little or
no cuttings in screen filter. No unusual noises or grinding sounds. This tractor may come up for sale as-is and I am curious what
I may be faced with. Thank you in advance for any information.
If this thread interests you, I have a similar thread going at the main forum also. Thanks to everyone there for the excellent information provided.
It appears from reading your other thread that Tim & some other posters answered your question. Good luck with the 4440. I'd suggest as others stated to check cab mounts 1st.
