Ok -I have the brake assembly off the tractor and apart. Now the problem- The brake adjuster is very solidly frozen and does not want to turn at all. I have tried LOTS of liquid wrench, WD-40, Creep Foam, etc -etc till I'm sick of it. I guess I am ready to go all out and take it to my local welding shop and put some very intense heat on it!
After I FINALLY get things loose -is there available replacements for the adjuster and those little slotted shafts that engage the brake shoe????
The left side went just fine and actually worked very well after installation. This is on the right side and I'm starting to get a bit perturbed with it! I do have a replacement and just maybe I need to work on the replacement drum and brake assembly and give up on the one I took out! However -it is froze up as well!
Suggestions??????
Suggestions??????
