I have a 4430 that has 2 hydraulic fluid leaks which are bad enough they need to be fixed, and I can use some help. I will list them in separate posts. Leak #1 is where a line goes into a structure that I can not identify or find in the parts diagram.
I attached a picture. The leaking part is on the left side of the tractor just behind the hydraulic fluid filter. It is leaking where the line screws in...I have tightened this as tight as can be. Suggestions?
Thanks!
Rich
Thanks!
Rich
