3020 hydraulic leak
kRM1976
Feeding cattle today and i noticed oil by my feet, it is leaking around by the steering wheel. Is there a seal behind there? I didnt think hydraulic
oil should be that far up on the shaft. Thanks
Your steer valve needs re-sealed and re-calibrated, I can help you with that,and bench test it, if your interested..
The seals beneath the steering wheel do not
hold pressure oil. Your leak is at the oring
above the cylinder. The last thing you get
to when disassembling the valve housing.
A job you cannot do.
