B steering bearings
nl00sb
B steering looking for part numbers for the two front bearings on the steering shaft front and back of the worm gear , are they the same as the
G ? Thanks for the help
The cone and the cup of both bearings are the same. They're different on an A and I would think also different on a G.
Cone is JD7396R
Cup is JD7419R
You probably only need the cones which are the same as Timken 11-BC
According to JD parts catalogue, the part # for those bearings on a B is 7396 R. For a G it lists 7205 R. I hope this helps you.
Careful as all B's are not the same bearings. you do not say year or serial number. The unstyleds are different. Not positive when the change was without digging out the parts books.
