I have been stalking this forum for months. I have not found my answer. I have been working on a 61' 4010 diesel with great success and have run into a problem with the brakes. They were working properly before I removed the value and rebuilt with the cheap kit and replaced the boots with the boot assemblies. I also speedi sleeved the pto. The pto and brake valve are not leaking ( they were prior). I filled with hydraulic fluid.
I have nothing on the brake pedals. They sit all the way down. I have let it run for a while a tried to bleed with no change in the pedal/valve. As I said, the brakes were fine before dismantling.
The 3-point works, the power steering works and the transmission works. Any advice is appreciated.
