3010 leaking engine oil at filter cover
Ray IN
What would cause engine oil to leak, only when running, around the bolts holding the filter cover in place? I've got to get this tractor fixed which is in the school shop before the end of the year because I am retiring from teaching. So help or I will be stuck there another 32 years!
Have you replaced O-ring #4, and gasket #9?
If you remove housing #8 to replace gasket # 9, replace O-ring # 34, as well.
<img src = "http://jdpc.deere.com/pimages/RGP4/RGP4404________UN14DEC94.gif">
