Have a 62 3010 that has a strange squeal in a hydraulic line. The large hydraulic line coming / going from the control block to the hydraulic pump makes annoying squeal but only if you are trying to control the 3 pt in small amounts. Once the arms are in the position set with control squeal stops. If I raise the arms from bottom to top no squeal. If I use an implement such as a planter or using a smoothing harrow such that the arms are not all the way down it will squeal off and on as the implement moves across uneven ground. Changed hydraulic fluid and filter. Old fluid was very clean and inlet screen was really clean as well. Any suggestions as to what may cause this?
