721BSCHMIDT
New User
On a 1953 JD 70 gasoline, I was having trouble with the throttle moving back a little when running at full idle. So after looking into it, I found two worn out friction discs, and a broken spring. I replaced the plate along with 2 new friction discs, and a new spring. I tightened the spring so that there are about 10 lbs. of pull at the end of the throttle like the book calls for. At fast idle or wide open as some would prefer, the throttle comes back just enough so that my best guess is that I am losing maybe 50-75 rpms. Any thoughts on what I can do for adjustment with the linkage between throttle and governor, or governor to carburetor for that matter? Or do I need to look at some other issue?
