Need help estimating value of 820 for the widow of a coworker. Looks to be an original tractor, really clean sheet metal with some light surface
rust showing. Stored in a barn from dry Eastern WA , 23.1x 26 tires are about 30%. Has pto, single hydraulics, foot throttle-decelerator. I
spent a few hours and cleaned the gasoline tank, lines and carb, topped off oils, watched a couple of videos on how to start it and then it did.
Ran really well, pony seemed to run a little rich but smooth and with good power, main engine kicked right off on a damp 40 degree day..
charging system works, 6 volt yet but no lights worked. No pictures as it was to dark in the barn but would like some help as to current value.
Not very up to speed with the green ones, usually play with red or orange. Thanks for your help, Mike
