I just pulled a mower out of the shop today, that I bought as a
project and quickly saw that I needed to go through the cutter
bar modules. I had to replace a couple castings and a couple
gears. Replaced and few bearings and all new seals, after
cleaning everything up. All the timing marks are correct on
the shear hubs, and all the units were put together 90* from
one another. Where I went off book, was where I decided to
use Kuhn straight blades without a degree of twist. I run this
type on my Kuhn machine to help guard against stone
damage. Deere didn't offer the flat blade, but I noticed the
Kuhn blade was the same, just without the twist. The issue is
the blades are tipping at 45*. It appears that if I put the Deere
twisted blades on, that the leading edge of the one blade will
clear the underside of the lifted edge of the other. This
sounds a real stretch to me that it could have been built with
tolerances that close. The Kuhn had no issues when I
switched to flat blades. This bar is set up to rotate toward the
center. If they want to tip at 45, I don't see how they could be
set any farther apart by adjusting the timing of the pinion
gears. FYI the flat blades measured the exact same length as
the twisted blades. The service manual didn't talk about
timing between modules, as long as they would mount the
turtle shells 90* from each other. Is there something I am
missing? I was really hoping that I could run the flat blades
on both machines.
on both machines.
