Wreckmaster
I was going to buy a pull scraper for the JD 70 today. Now keep in mind, I have only run 30 hp tractors with 3 point hitches so a small box blade is the only thing I have used. My JD has only a pull hitch. My question is…the pull scraper I found is the tilt type with 4 hydraulic hoses for the up and down and side to side tilt. I only have the two hydraulic hook ups for the up and down. Is there any way or adapter to make using the up and down, and the tilt side to side possible using the JD70? They have the up and down only scrapers with just two hoses but would like to have the side to side tilt option if possible. Thanks for your input,,,, Mark
