humblesmith
I have a JD 2640, 4 cyl. 276 diesel. We did a lot of work on it, including replacing the pencil-style injectors. According to the JD parts book the new injectors are supposed to have a washer and a seal ring on the bottom, going into the head.
The seal has exactly the same outside diameter as the injector......which means it will not slip over the injector.
How am I supposed to install this seal? Does it slip down into the head?
JD part numbers:
R48000 seal
R34764 washer
JD part numbers:
R48000 seal
R34764 washer
