Hello,
I was wondering if someone may be able to help me understand how the throttle stop screw/spring is supposed to be set up on a MS DLTX 67 carb? My engine is currently hunting, where it idles down then the governor picks it up but repeats the process. There is a lot of movement going on in the linkage between the governor and the throttle. Would someone potentially be able to post a picture of what your throttle stop screw and spring look like at full throttle position, as well as at low idle position?
Thank you kindly.
Thank you kindly.
