LUC magneto
I think it will be close enough. I don't have the right mag so I am going to use one from a V4 Wisconsin & ground the 2 wires not used. I think they are 25 degrees. I may try to run it on E85.
One problem I may have is fine tuning the timing as the mag is bolted on with no way to adjust. I may have to shim it out so the bevel on the gears will change it.
