Need some inputs on how to troubleshoot this. Here is the problem - Clutch engaged -PTO engaged - Oil in the unit - moving the lever has no effect. Power lift does not move.
With power off and tractor shut down - I put a BMF pipe wrench on the lift shaft and it does not want to move -either direction! It seems to be stuck with no movement at all.
So - Suggestions??? Don't tell me to get another tractor!!!
