Power Trol conversion
KWV63
New User
I have a 41 B that has the power lift. I would like to replace with the Power Trol. I haven't found a lot of specific or details about the change, but from what I have found it is basically just a simple bolting on the PT unit in place of the PL unit. I'm starting my search for a PT unit and was wanting to know what model tractors have would be compatible with my 41 model.
Anything from an A, B, G, 50, 60, or 70 should fit. Get the bolts, too- one or more is a different length. It is a simple unbolt one box, bolt on another.
And one gets a copper washer instead of a lock washer because one bolt is open to the reservoir & will leak oil if a lock washer is used. Sticks in my mind it's one to the upper right but I could easily be off on THAT! Easy to tell which bolt gets it if you look at the unit before bolting it up!
