Power troll -How does it work???
MARV2015
I have a 1952 "A" with a powertroll or rock shaft as I tend to call it - and I need to find out how that system works!
My cousin told me to check and see if maybe it is in the UP position - when it is running I can move the control handle forwards and backwards and there is no movement in the rock shaft. At first -he thought it may just be in the "UP" position and since there is no load attached -it will not come down.
I tried a bit or leverage with a large pipe wrench and an extension of 2 inch pipe -(4 foot!) and no movement seems possible.
If it is stuck in place -What do I have to do to fix it????
"<font color="#6699ff">[b:654c4848f0][i:654c4848f0]What do I have to do to fix it????[/i:654c4848f0][/b:654c4848f0]</font>"
Agree with [b:654c4848f0]Mark-Ia[/b:654c4848f0] that the "[i:654c4848f0]PTO and Clutch need to be engaged for the PowerTrol to work.[/i:654c4848f0]"
Take a look at the diagram below.
a151437.jpg" width="650"
Note the shifter lever (Key 58).
Take a look at the photos below of the shifter lever.
a151438.jpg" width="650"
a151439.jpg" width="650"
Hope this helps.
All right -I have to give you all a BIG APOLOGY!!! I thank you for the information provided and to inform you that I now have this little problem figured out!
Thank you!
Now the rest of the story-I was actually trying to get the "Power Lift" to work! I had to go back and look at the exploded parts diagrams to figure out the I have been wrong in what I was asking for! I will submit another post with the CORRECT terminology!
