4430 Brake Accumulator
Working on this tractor trying to fix all the oil leaks. I assume what I am looking at is the brake accumulator. Can't tell yet if this is where the oil is coming from until I get hydraulic pump back on tractor. Is this a fairly common area for leaks and how bad of a job is it to repair? Thanks!
[/img]
Metering pump has been rebuilt and converted to hydraulic hose fittings on base. Will have to put hydraulic pump back on and try and isolate.
