johndeeregreg
i was noticing the front tires on our 8400 have some uneven wear, on both tires the right lug is noticeably wore down further on the center 2/3rds of the lug, the other 3rd of the lug and the lugs on the left side of tire have what i would consider normal wear. have done seals in both sides of axle with in the last 6 or 7 years one side more recently that the other so the hub bearings shouldn't be loose. does a guy need to check king pin bearings for extra play? would think if king pins were loose both tires would have the abnormal wear on the inside lugs. have seen similar wear on other mfwd tractors just wondering why and what can be done to prevent it
