Been quite a few years since I was on here, but life got in the way.
I've got a 60, sn6039096. Have used the PTO once since I bought it back in about '02, and had to almost break the lever to get it engaged. Decided to work it over now.
First of all, previous owner put 80/90 in the PTO instead of hy-gard. I know it's not leaking from the transmission/rear end. I changed that when I got it, and level hasn't changed.
I bought the service manual for it back in '07. Got that out to start this, and find out that it's for the earlier models that use the locking tab for the clutch adjustment, and this one has the set screw.
When I look in the fill hole, the set screw isn't in one of the slots. It's been adjusted enough that there is 1 thread showing between the set screw and the adjusting collar.
The space where you check it is close to .135 with the clutch engaged, and it's supposed to be .060" according to the service manual, and the operator's manual says .090". I'm assuming the .090 is the right one.
I can see that the adjusting collar is screwed back far enough that it's almost half off the threads. That, along with the spacing from the set screw, I'm guessing that the clutch discs are shot, and need to be replaced.
Help me out here, please. I should be able to drop the outer housing off and replace these, without dropping the whole power-trol, rockshaft, seat assembly off, right? Or do I have to tear it all down and pull the pump and shafts even though it's not leaking from the tranny?
Gonna have to check around for pricing after looking at the clutch pack from Deere. Ouch, they're proud of that.
Is Steiner's a good option?
Thanks.
Thanks.
