Got started on the rebuilding of the hydraulic, steering, brake, & rockshaft systems today. I started up front with a new pump & rebuilding the steering motor. The steering valve is going to be sent to Tim S. I'll be splitting it to fix the issue of the pto stub shaft coming loose. Also will be checking the trans pump, replacing o-rings on the pipes, & whatever else I find in there. It'll be getting a brake valve overhaul & all new brakes. Rock shaft valve & housing will be gone through. I rebuilt the rear couplers last year.
I've been having hydraulic systems issues with it for a while & decided to do the whole works at once & hopefully be done with that part of it.
How does a guy get the photos to not flip over when uploaded? Sorry.
