I have a JD 2650 (mostly the same as 2755...) the high low shift only works when hyd oil is cool/ cold. I understand that it is probably the clutches in the high low..?
I have to replace the clutch so I'm planning on fixing the High Low at the same time.
I have done a few IH 56, 66 and 86. But no JDs Maybe a 3130/ 2840 bout 30+ years ago...
My questions..
1) Where is it, I presume it is behind the transmission.
2) It has a cab, i have changed clutches a few time and you dont have to remove the cab. just unbolt the front, remove the right front cab support and the 6 bolts and out she come.. so can I leave the cab on?? Looks like can, just have to jack it up and block up (safety first)
3) Anyone out there fixed a High Low? Or is this a JD specialty item?
Thanks for all the help!!
My questions..
