Tylerpresser14
So as I am replacing the muffler on my b I found that there is no heating fins in the front I have the knob on the dash but I was wondering if it was an option or standard and was removed at sometime during the tractors life my second question would be if anyone is running theirs still as an all fuel and if they are are you running strictly kerosene or a diesel gas mix and what your mixture would be my third question would be it takes a lot of turning to get it to start my carburetor seems to be a bit off when running it has to have about a quarter choke should I turn my idle screw in or out it is just off a rebuild that I did myself and made sure the passages were open had to rework the nut and threads ended up cutting a pipe and tig welding it to the base where the last one had been saughtered cut a union and tig welded a bolt head to it made the depth the same and oringed the outside around the bowl for a seal
