CB injection pump leak
Roger in Iowa
1970 4020 with a CB injection pump leaking where the throttle lever attaches to the vertical tube coming out of the top of the injection
pump. Can this be fixed without taking the injection pump off?
Yes o rings But it has been years since I did it . I think that throttle control is like rack and pinion maybe spring loaded . I have done it on the tractor .
I have repaired several of these by just replacing the o-rings in the throttle throttle plunger. Not hard to do. less than $10 worth in parts. Not out much if it decides to start leaking else ware later.
Easy enough to do.. 2 orings, 1 on each side.
Just pay attention to the throttle angle.. Idle at 12:00??
It can go back many different ways..
Probably a REAL GOOD TIME to flip the gear also..
