Still looking for LA belt pulley assm. that I posted yesterd
46chief
I still need to know if the oil tube that is in the casting is placed in the lower position when it is put on the tractor or where. If? this is so then the inlet holes would be on the side. Is this correct
When I installed mine I want to say that oil splash hole was facing front, not top or bottom. If you look its like a tunnel and you have to position it show the oil will flow or splash into the hole. I just went with what made the most sense, which was, I think, facing forward. Worse case scenario, put it on, run it, and then take it off. If the assembly is dry you know that wasn't the right way and try another position.
