1949 John Deere A updates
7060
New User
I started working on my 1949 A that I recently purchased. I have a 1952 parts tractor with a water pump and split pedistal. I also have a wide front that I am wanting to put under the 1949. Can I swap the split pedistal and water pump radiator over to this tractor? Is the water pump necessary to keep the tractor cool? I'm going to run it on an auger.
The front fan shaft support needs to be changed when you move the cross member back.
