jtgaff
New User
I need a part number for packing / o-ring that seals oil pressure entry from main hydraulic pump to rock shaft assembly case. I looked on JD parts both for rock shaft assembly and transmission case. thanks
(quoted from post at 22:26:50 01/18/17) I need a part number for packing / o-ring that seals oil pressure entry from main hydraulic pump to rock shaft assembly case. I looked on JD parts both for rock shaft assembly and transmission case. thanks
If your're referring to an ind JD 300 then the answer is PN T17882(key 13) is the quad ring seal that fits in trans case recess to seal pressure from trans case to rockshaft housing
