Hello:
I have a 2014 JD 6105D that has 507 hours. I changed the oil and oil filter two times so far: at 100 hours and used JD Break-in Plus oil and at 500 hours and used JD Plus-50 15W-40. The low oil pressure light came on before the oil change at 500 and it came back again after I changed the oil and oil filter at 500 hours.
The oil level is fine. The engine runs fine. The light comes on after the tractor ran for few minutes. How shall I check whether either the sensor went bad or the pump went bad?
Thank you,
Paul
Thank you,
Paul
