If I have one off and want to clean it I use degreaser and a HOT water pressure washer. I keep going until I see the water run clear.
Best to remove from tractor and agitate Briskly in a 5 Gallon Bucket with your favorite Solvent) UP and DOWN until you get the debris out, then again in clean solvent (Rinse).
I used gas in 5 gal bucket.Fill bucket 2/3 full,turn the
breather upside down the second day,shake it up and down several times,blow it out with air when done.
