Front end hitches, new gen specifically
SHALER
Anyone have any details on hitches they have made or purchased for new gen JD?s that you would fasten on to the tractor by using the 2 carriage bolts on the front weight pads? Would be used primarily for pushing hay wagons around, both empty and loaded.
I have thought about it. I would just take a front end weight to a welding shop and have them build it. I would also use hard bolts. Tom
I just torched some holes in a piece of angle iron and bolted it to the tractor. I push around 5 ton of corn with it. This is on a 3010.
Something i'm starting
