3010 HYD filter
craigco
Am I correct that you can change the HYD filter with out draining the system? What about the screen? Thanks
You will loose about two quarts when changing the filter. When checking the screen I usually take it loose and remove the plug and pull the screen and reinstall the plug without draining the trans. Sometimes the screen will fight you a little going back in. I always have two clean five gallon buckets ready in case for some reason something does not go together quick enough. Usually out and back I loose less than two gallons. I also like to put a cow magnet inside the screen when reinstalling. This catches lots of small fines that pass thru the screen. Tom
On checking sump screen you can insert the nozzle of a running shop vacuum into hyd filler hole to create a vacuum to limit oil loss while pulling screen.
