gidtex
My 4020 has got 18.4-34 rear tires and 6.00-
16 on front.im wanting to put wider tires on
front because of loader.what size would
leave the front about the same height.
I have one with 11Lx15's and one with 10.00 x 16's. I like the tall tires better. The one with the 11L's is a narrow front, so that's the biggest that will fit. With a wide front, I would use the 10.00 x 16's. My neighbor has one with 11L-15's with a wide front and wishes he had taller tires. With a loader, if you get in mud or soft ground, the taller tires will roll easier.
I have one 4020 with 18.4x34, one with 18.4x38. Each has 11.00x16 three rib fronts. The one with 34s has a loader on it and works n looks fine . Al
11L-15s will set more level. 10:00-16s will hike the front end up a bit, but some of that might be offset by the weight of the loader itself. I would probably lean toward the 10:00's myself knowing that you have a loader on it.
Use larger diameter tires on front with a loader. You will break less spindles on rough ground.
11L x15 4 rib Firestone on 10in rim would be level.Tire brand, rim width,tri rib,4rib,flotation type all make a difference.10x16 look good about 2in+ taller.11x16 a little too tall match better with 42s.What ever you like is probably best answer.
My older 4020 came to me with 18.4-34's and 11L-15's. I later updated to 10:00-16, then 11:00-16. I later put step-up 38" rims on and run 18.4-38's on it. I never liked the 11L-15's as they were just too small. For loader work either of the 16's will work better. The 10:00-16 matches the 34"rears pretty well but the 11:00's really don't look too bad. The 11:00's and 18.4-38's on it now work very well for loader duty and look "even". To my estimation, 11L's are simply too short on a 4020 with,any 18.4 tire. Mike
