johndeeregreg
i put a factory wide front on my 720 last spring and now it is leaking under neath i used the same bolts on the steering arm that came off of it, i switched it from 1 tractor to another so I'm pretty sure the bolts are the right length as the one it came off of wasn't leaking. is it just coincidence that it started leaking after i switched front ends or does not having the weight of the tractor pushing down on the pedestal have something to do with it? i have seals, bushings, and bearings ordered to do a complete reseal just wondering if this is common when switching front ends?
