fixerupper
The one beside the seat is it the same for the A,B & G? I'm running into a little confusion ordering one. I thought they were all the same but the source i'm looking at has a lever for the A & G, then another lever for an A that will fit the B & G! There is a difference in price too. This 47 B I am working on has a Baker valve and Power Trol. I thought a Baker was added to a tractor with the power lift but isn't needed when the tractor has a Power Trol? It does NOT have the distributor mounted live power pump. I don't know much about the Baker valve or Power Lift but this tractor has both. I suspect this tractor had a power lift and someone added a Baker valve but later took the power lift off and put a Power Trol in it's place but left the Baker valve on? the Power Trol was hanging on there loose. all the bolts were loose like someone took it off or started to take it off. The owner can't remember details.
