John Deere 40
jerryinga
Once again I am in need of help I am currently working on a JD 40 I purchased a couple months ago. The tractor is running rough. I have had the carburetor rebuilt by Yesterdays Tractor, replaced all the wires, plugs, points, condenser, rotor and cap I have set the timing adjusted the valves and it stills runs rough. It seems to be skipping (but not steady) and is more noticeable at full throttle it is popping slightly. With the muffler off you can see fire coming out of the manifold. Where do I go from here
Thanks Jerry
Jerry,It sounds like it is running lean on the fuel mixture.Open up the main jet 1/4 turn and give it a try.
Is that "fire" coming out of the manifold a glow or just z pop of fire when it misses?
I have seen them glow if the timing is set on TDC instead of Spark.
the LOAD mixture screw on them seem to need to be turned out farther than you would think to get them to run right. And the idle screw on those works backwards as it adjusts the air. So in will make it richer.
Without hearing it though it might just be normal. They don't call them popping johnnies for nothing.
The flame is only when it pops also I have noticed the top of carburetor and the lower part of the manifold is cold and sweating. Am I right back the load out to richen. Could it be clogged fuel filter causing it to be starved for fuel
I am with B&D. If it isn't doing it all the time I bet you have a worn distributor bushing and it is allowing it to skip out of time, every now and then, ever so slightly.
The key is pick one thing and work on it. Work on just the fuel first and if that doesn't fix it then go to the timing/distributor. If you start messing with both at the same time you will make a troubleshooting nightmare for yourself.
One other thing that might help us find the problem
I never have to use the choke and it cranks first time every time
BUT, since he never needs to choke it, I say the Idle is set a little too rich also...
I can set my 630 just a little rich ( Idle) and it will start Cold on the 1st turn..But, set "correctly", I need to choke that bad Boy Hard to start it ..!
Got a chance to work on the 40 this afternoon
This is what I came up with the Load set at 1 1/4 and the idle completely closed
I am wondering if the carburetor rebuild was bad It runs pretty good at this setting but I know that's not correct what's going on
At no time will the Idle be set Closed...
I would double check the Carb and be SURE ALL passages are open..
