johndear720
My 2640 clutch releases fine at idle. At higher engine speeds have to shift quickly or it grinds and have to idle engine down to be able to shift. It has a button clutch, pilot bearing is new, no serious wear in flywheel or pressure plate. Intent to put an organic clutch in it. However, what's the chances the countershaft friction plugs / springs are worn out and that is the real issue? Is it common for them to wear out? It would appear to remove the counter shaft to replace those plugs is a lot of sugar for a dime so to speak. Split tractor at clutch and transmission, remove the rockshaft housing and slip everything off the countershaft to get it out just to get to $100 in parts that may or may not be worn out. Just how much resistance do they provide? How hard should the input shaft be to turn if they are working as designed? If the clutch is releasing properly do they really make that much difference?
Hi-Lo, independent PTO, no reverser
Thanks,
Thanks,
