8300 injection pump removal
8850dave
How difficult is it remove an injection pump from an 8300 tractor ? I need to have pump taken into a pump shop have an engine code that requires the pump to be worked on in a pump shop.
not to bad, make sure engine is on tdc #1 and timing marks lined up before removal. the 2 nuts on back side of pump can be a little difficult but with patients an the right amount of extensions and swivels you'll get them. remove the 4 torx head bolts on front of gear and leave gear with engine, not the big center nut that holds hub to pump shaft.
