JD 2350 hydraulic line
mjbrown
I need to replace the small return/overflow/ whatever they do lines because they have become brittle with age. One goes from the pump up to a tee on the top of a tank above the radiator. The other goes from the same tee back under the hood on the right side then down and disappears under the SGB. I need to know where it goes and how to access it to change it. They just push onto hose barb fittings so there must be little or no pressure in them. Thank you.
I have an owners manual but nothing in it about this.
Attaching point on shifter cover that Tim referred to is key 12
Buy the good hose from Deere. I used some cheapo hose from the farm store and it only lasted a year. You will need about 4.5-5 feet to do both of them. This is the overflow from the hydro reservoir. On my open station, the hose slips on a short stub of 1/4in pipe sticking up from the tranny case about 2 oclock from the right shifter. The stub points 45 degrees from vertical pointing to the front.
John
