I would like to change my 720 from 6 volt positive ground to 12 volt negative ground if possible. I found a set of 12 volt car coils I can use to replace the six volt JD coils, so this will not be a problem. Also I already have a 12 volt alternator that I can use to charge with, and I have a 12 volt fuel gage I can use, and I already have 12 volt lights I can use.
My concern is the the starter. Will the 6 volt starter on a pony motor run without damage if you use 12 volts and negative ground? Will 12 volts effect the capacitors or the points in any way?
