Re: 3020 hyd issue
tim s
You can't see the worn spot on the cam, it's under the roller bearing,, this is a place that can cause your vibration..the needle bearings rolling over a bad spot...you should consider an new after market pump rather than changing pump shaft and bearings..around $900...just my thoughts...
More times than not it's best to replace an old pump rather than reseal it, bearings, shaft, seats and bore get worn more than you realize..
