Fr you 1020 experts...
Can you tell from this picture if this 1020 is a gas or a diesel?
I think I see a distributor and coil.
Distributor is at an angle, diesel would have a straight-mounted fuel filter in that area.
I also think it's a gasoline model although photo gets very blurry when I enlarge the photo.
Injection pump is mounted on LH side of engine on a 300 series engine such as the 1020 utilizes
centash, don't you have that backwards? Red fuel cap should indicate gasoline, but who knows if the fuel cap might have been switched.
This is amusing,, sounds like some one choosing LOTTO numbers...from the position of the picture you may as well be looking at the draw bar to determine the engine...
