Thermal relief valve
craigco
Do you know the part number for a thermal relief valve for a 3010? Can't find it on the part site. This is for the diesel 3010. Thanks
I was under the impression that the thermal relief valve was different then the valve number from previous post. The diesel 3010 had the dropping 3 point when shut off. Most off the posts on that call for new thermal relief. Is this correct or will the AL number possibly solve this problem also? Thanks
Sorry for mistake. I think my pea brain wasn't engaged this morning. What is your tractors serial number? IIRC keys 7 & 8 are the thermal relief valve for older tractors but there's serial number break at 032399
On the early 4020 it was leaking down when shut off too. I was able to take it apart and clean the seat up and get it working. Been a long time ago can't remember if it has a ball bearing for the valve ? If so I would of welded a rod on one for an extension and used lapping compound to clean up the seat. I have one of these custom tools laying around somewhere and I think that is why.
Not sure on serial number. Was sold as a 61 seems like it was a 20000 number will check when I get home this evening. Thanks for the help.
