Unstyled A powertrol
Mark Poss
I pulled the rock shaft housing off of my unstyled A to fix it from leaking into the transmission. I pulled out the seal from the pro shaft AB2578R. The only other thing I see to replace is the gasket A623R that goes between the cylinder and the housing. Is that it or is there more? thanks for your help, Mark.
