"<font color="#6699ff">[b:654c4848f0][i:654c4848f0]When I push the button on the starter switch nothing happens. What is the chances of that being the problem?[/i:654c4848f0][/b:654c4848f0]</font>"
Before you begin troubleshooting:
Lock [b:654c4848f0]BOTH[/b:654c4848f0] brakes.
Shift the transmission into [b:654c4848f0]NEUTRAL[/b:654c4848f0].
Turn the ignition switch to the [b:654c4848f0]OFF[/b:654c4848f0] position.
Turn the gas [b:654c4848f0]OFF[/b:654c4848f0] at the fuel filter.
Take a look at the diagram below.
Note the starter opening cover (Key 23).
Take a look at the photo below of the location of the starter opening cover on the engine and transmission case.
Remove the starter opening cover and check for power at the starter switch.
If there is no power at the starter switch, then check the cable connection at positive terminal on the battery.
If there is power at the starter switch, then push the button to engage the starting motor.
If the starting motor does engage, then check and/or adjust the starting motor pedal and linkage.
If the starting motor does not engage, then remove the starter switch.
Note the stud terminal (Key 12).
Briefly touch the battery cable to the stud terminal.
If the starting motor does not engage, then remove the starter.
If the starting motor does engage, then check both the starter switch terminal and stud terminal for excessive wear.
Take a look at the photo below of the starter switch.
Check for excessive wear on the leading edge of the starter switch terminal.
If the starter switch terminal is worn excessively, then replace the starter switch.
Take a look at the photo below of an excessively worn stud terminal.
If the stud terminal is worn excessively, then replace the stud terminal.
Take a look at the photo below.
"<font color="#6699ff">[b:654c4848f0][i:654c4848f0]I would assume if that is I want the one without the side screw?[/i:654c4848f0][/b:654c4848f0]</font>"
Note the black wire from the starter switch side terminal to the output terminal on the ignition resistor.
If you want to install an ignition resistor bypass wire, then you will need a starter switch with a side terminal.
Take a look at the photo below of the black ignition resistor bypass wire.
Hope this helps.
