JD A clutch questions
rb54
I have a 46 A and my question is can I use the triple disc clutch set up from a 648000 and up on my A using the original belt pulley. I need a little more grip since I upgraded the engine. Any help is appreciated
No you would need the pulley and the first reduction gear from the later A .if you are interested in these parts I can help as i have all on hand
If your clutch components are in good shape (toggles/dogs/disks/operating pin) the 2 disk system WILL hold over 100 HP (BTDT). If you are
well over that, you may need the late A components. Adjust the clutch on the tight side, and use a longer clutch lever from a 60.
We have clutch disks with with ceramic pads for sale. We use them in pulling tractors with good success. Email is open.
