Finger Timing adjustment for 200 series Deere heads
wilamayb
I noticed that there is no adjustment for the auger fingers on the 200 series platforms. The old Deere headers had this adjustment and I
know the newest heads have this adjustment. Do the 200 series not adjust? I cant find any mention of it in the manual.
There is some adjustment...better check inside and make sure no bearings are out..or the arm bolts are sheared..or the arms are broken!
Can raise the auger a touch if need be(nothing broken or worn-out)
Mike, I wish you were right.. The bracket has two holes. I thought perhaps the base plate was slotted but it is not.. The operators manual doesn't mention it either. I may slot mine...
